SHEWIK писал(а):
Не пошла! (((
Кто нибудь знает, че это значит?
Wolfenstein The New Order.1683.12143 win-x64 Retail May 18 2014 15
------ Initializing File System ------
Current search path:
C:/Users/Roman/Saved Games/MachineGames/Wolfenstein The New Order/base/
C:/Program Files (x86)/R.G. Mechanics/Wolfenstein - The New Order/base/
file system initialized.
BenchmarkGameData: ofs 0 and 0x151060480x
86 microseconds
37 microseconds
35 microseconds
34 microseconds
32 microseconds
35 microseconds
36 microseconds
37 microseconds
34 microseconds
36 microseconds
Average seek time without outliers: 35 microseconds
fileBenchmarkImpliesGameIsOnHD: true
idStreamingInstallManager::Init: using langMask 1 for lang russian
1 CPU package, 3 physical cores, 3 logical cores
log file 'qconsole.log' opened on Thu Feb 19 22 2015
2100 MHz AMD CPU with MMX & SSE & SSE2 & SSE3
65536 kB 1st level cache, 524288 kB 2nd level cache, 2097152 kB 3rd level cache
3072 MB System Memory
Winsock Initialized
Found interface: {47FF4E05-5A4F-4191-9153-E200712D30B9} NVIDIA nForce 10/100/1000 Mbps Ethernet - 192.168.1.2/255.255.255.0
Sys_InitNetworking: adding loopback interface
Executing default.cfg for device #0...
execing joystick.cfg
Executing default.cfg for device #1...
Executing default.cfg for device #2...
Executing default.cfg for device #3...
idLib::SetProduction( PROD_PRODUCTION )
OpenDLCFileHandles: 0 packages mounted.
WARNING: Config file "wolfConfig.cfg" not found
Command line is: "C:\Program Files (x86)\R.G. Mechanics\Wolfenstein - The New Order\WolfNewOrder_x64.exe"
------- Initializing renderSystem --------
PreliminaryRenderSetup
---registered window class
---registered fake window class
---registered context window class
GetWGLExtensionsWithFakeWindow: OpenGL Vendor: "ATI Technologies Inc."
GetWGLExtensionsWithFakeWindow: OpenGL Renderer: "ATI Radeon HD 3870"
GetWGLExtensionsWithFakeWindow: OpenGL version: "2.1.8787"
---using WGL_EXT_swap_control
X..WGL_EXT_swap_control_tear not found
CreateOpenGLContextForCurrentThread: Assuming pre-checked Graphics Vendor: "ATI Technologies Inc."
CreateOpenGLContextOnDC: Using gl version 3.2
ERROR_INVALID_VERSION_ARB: 0x2095
WARNING: No address, error: 487
WolfNewOrder_x64.exe @ 0x3fb7c03d( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3fb09210( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3fb0946d( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3f5ac9d1( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3f5acacc( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3f5af431( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3f5b001a( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3f5ab5ed( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3f273305( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3f627990( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x3fb4523f( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
kernel32.dll @ 0x76e459ed( ) + bytes () : BaseThreadInitThunk( )
ntdll.dll @ 0x7707c521( ) + bytes () : RtlUserThreadStart( )
FATAL ERROR: wglCreateContextAttribsARB failed
Dumped console text to C:\Users\Roman\Saved Games\MachineGames\Wolfenstein The New Order\base\ErrorLog_19-02-2015__22-05.txt.
idRenderSystem::Shutdown()
Shutting down OpenGL subsystem
...у тебя система слабая...проц не тянет, памяти не хватает...ну и походу карточка тоже не вытянет...говорю меняй начинку...
